Re: Farmall BN electrical
Posted by Bob M on February 16, 2007 at 05:05:51 from (151.190.254.108):
In Reply to: Farmall BN electrical posted by Kaptkimbo on February 16, 2007 at 04:46:28:
The stock BN came 6 volt from the factory. So yours had to have converted to 12 volts sometime later. And there's many possible was to convert to 12 volts - so there's literally dozens possible wiring diagrams.
Post back whether your BN has a generator or alternator. Also the manufacturer of the generator/alternator, whether it has an external voltage regulator, and if so the number of terminals on the voltage regulator.
With this info (and a bit of luck...) we should be able to identify a schematic that will work for you.
