Re: MW 9 speed in super M is it different than M 9
Posted by D Slater on February 16, 2007 at 06:55:15 from (152.163.100.199):
In Reply to: MW 9 speed in super M is it different than M 9 spe posted by Steve Sawyer on February 15, 2007 at 20:33:45:
Difference between M&W parts and tractors is 3&4 drive gear, 4&5 slider gear, shifting sleeve mechanism size on lower shaft and range gear bushing. To put M in SM use the M counter shaft with all M&W parts,change reverse idler gear and slide all M gears with the one M&W gear on your main shaft unless its bad.Use the M&W input shaft. Whichever shift type you have will interchange. May find some M&W kits have little differences. I like the gear spacing for a M better than SM with M&W.1&2 slider gear will interchange between tractors,but I would change all that was set if good. If wanting PTO don't use early dog type counter shaft from M.I would stay away from all real early gears in M also.
