Re: Diode Warning Light
Posted by Nat 2 on February 16, 2007 at 12:48:48 from (64.80.110.27):
In Reply to: Diode Warning Light posted by SuperA-Tx on February 16, 2007 at 12:24:12:
The light/diode isn't supposed to be "grounded to the frame." It's installed in between the ignition switch and the #1 (IIRC) terminal on the alternator.
I picked up a simple panel mount red LED at Advance Auto Parts, stuck it in the electrical box in place of the fuse holder. Cost $5.48. Works fine.
Really, getting the exact part is not all that critical. Just get something close and you'll be fine.
