Re: Diode Warning Light
Posted by farmallhal on February 16, 2007 at 13:09:23 from (64.24.35.16):
In Reply to: Diode Warning Light posted by SuperA-Tx on February 16, 2007 at 12:24:12:
When I converted my 1951 H to 12 volt I used a 10 ohm 10 watt resistor in lieu of the light which I couldn't find around here. I also used a IN4004 diode so the engine would shut down when the switch was pushed in. Both of these items were purchased at Radio Shack. Don't recall the number on the resistor but anything similar should work as it's function is to excite the alternator into a charging mode. When installing the diode to shut off current to the coil the banded end must be toward the alternator. Hope this helps, Hal.
