Re: 12v conversion for super a
Posted by SuperA-Tx on February 16, 2007 at 16:40:40 from (4.90.14.242):
In Reply to: Re: 12v conversion for super a posted by John T on February 16, 2007 at 16:15:28:
John,
I been reading up on the ballast resistor and the 12 volt coil. Now from what I understand the resistor is to keep from burning up the points. Isnt the resistor still needed even with a 12V coil? I know you can get a coil with an internal resistor and I would go with that if I had it to do again. Mine has a 12 volt coil but I have a external ballast resistor as well.
Can you fill us in a little on that?
