Re: H Farmall dry sleeve
Posted by Tom Windsor on February 16, 2007 at 21:20:37 from (205.188.116.133):
In Reply to: H Farmall dry sleeve posted by thumbanger on February 16, 2007 at 15:43:41:
To Install dry sleeves:
Thorougly clean cylinder block bore and counterbore removing all carbon and foreign matter, wipe O.D. of sleeve; then use glycerine, stoddard solvent or other light sealing lubricant between sleeve and cylinder block bore.
CAUTION: SLEEVE MUST ENTER APPROXIMATELY HALF-WAY INTO BLOCK BY "PALM OF HAND" PRESSURE. IF IT DOES NOT, IT IS NECESSARY TO HONE THE BLOCK TO OTAIN PROPER FIT. THIS IS IMPORTANT SINCE A FORCE FIT WOULD DECREASE THE INSIDE DIAMETER OF THE SLEEVE RESULTING IN INSUFFICIENT PISTON TO CYLINDER CLEARANCE.
After installing halfway by hand pressure, us a good sleeve puller to complete installation. If no sleeve puller is available, cover the entire top of sleeve with hard wood lock and tap lightly with mallet to set in place.
I do not suggest that you use the heat on the block and the cold on the sleeves. Should be installed at ambient temperature.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
