Re: super c stuck in gear.
Posted by james jennings on February 17, 2007 at 14:07:14 from (24.239.184.102):
In Reply to: Re: super c stuck in gear. posted by gerrgeky on February 15, 2007 at 15:09:22:
i pulled the top off and found a aluminum or pot metal ring jammed in the reverse gears. the part number on the broken ring reads ih 354643-r11.
alittle investigation said that this gear is an oil slinger and is only necessary when the pto is being used while standing still. can you confirm this information, or do i need to pull the trans apart and replace.
if you or anyone has an opinion, i would appreciate it.
thanks,
james
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
