Re: M Farmall Info
Posted by Randy as in Randy-IA on February 17, 2007 at 16:34:40 from (207.177.83.66):
In Reply to: Re: M Farmall Info posted by Bigramjack on February 17, 2007 at 16:24:55:
It should have a lever or cable pull on it . The cable would be mounted to the right of the steering support and if it's a M&W the lever would be also . If it's a Heisler the lever would be on the left side but that's just a guess . My M has a M&W ( by the way it's called a 9-speed ) cable shift . I'm not familiar with the Heisler setup so someone else might have to answer that one . Either way it gives the tractor 4 more speeds between 4th and 5th gears . It also speeds up the pto speed . ...Randy
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
