Re: M Farmall Info
Posted by Janicholson on February 17, 2007 at 16:58:31 from (66.173.50.176):
In Reply to: Re: M Farmall Info posted by Bigramjack on February 17, 2007 at 16:40:15:
If he said it it more than likely does. There are components in the small cover behind the belly pump in the bottom of the tractor. These would be internal levers, and attachment points for the cable. Others can help with details, and possible pics. JimN
