Re: M Farmall Info
Posted by Randy as in Randy-IA on February 17, 2007 at 17:43:54 from (207.177.83.66):
In Reply to: Re: M Farmall Info posted by Bigramjack on February 17, 2007 at 16:40:15:
Ask for SKK , He has pictures he can post of the internals . One way to tell is if there's a small hole just to the rear and below the belly pump fill opening in the transmission tunnel ( torque tube ) on the right side . The hole would be verticle or slightly forward of verticle . This is where the cable entered the clutch area . Then it goes through a hollow dowel with a clamp on the outside to hold it in position into the transmission . Hope this helps . ...Randy
