Re: M Farmall Info
Posted by D Slater on February 17, 2007 at 19:14:13 from (205.188.116.133):
In Reply to: Re: M Farmall Info posted by Bigramjack on February 17, 2007 at 16:40:15:
Remove cover in rear of belley pump, look at top bolt on right side of tractor up inside that holds clutch housing to transmission and see if its non original.Cable passes through center of it on M&W cable shifted.Remove belt pulley gear box or cover plate and look in transmission for the M&W parts. Find a diagram of parts first so you know what to look for.
