Re: Super A Tranny Question
Posted by Roger Mills on February 18, 2007 at 08:17:07 from (71.213.68.215):
In Reply to: Super A Tranny Question posted by flic50 on February 18, 2007 at 06:28:50:
Only while the clutch is actually engaging or releasing??? Clutch disk will do that if nearly worn out-rivets riding on flywheel or pressure plate. It will probably slip if in high gear with a load. Clutch pedal probably starts to release very quickly or the adjustment is about out of room. Also, a broken pressure plate spring can do that but the clutch will usually chatter as well. Check out some of these possibilities.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
