Re: farmall smoke
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill B on February 08, 2000 at 06:04:41 from (209.182.66.206):
In Reply to: farmall smoke posted by james morris on February 08, 2000 at 03:01:20:
The most common cause for this is bad rings. The oil consumption is now noticeable because the valve job raised the compression, as they are no longer leaking. Now the worn rings have more blowby, and the worn oil rings can't make up for it. If it is really smoking badly, all the time, then I would suspect the oil passage to the rocker shaft is leaking through the head gasket to a cylinder. The head, block and gasket must be very clean when assembled, and a light coating of sealer helps. I use aluminum spray paint on the gasket, and apply it when still tacky. If it only smokes when first started, the valve guides are suspect. If it really smokes badly when you get to the bottom of a hill, and the governor kicks in to pull again, I would suspect the rings. Take off the oil filler when it is running, and see if you are getting a lot of blowby. My cub has so much blowby that when I take off the filler, oil splashes out.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
