Re: Cub Timing
Posted by El Toro on June 22, 2007 at 10:16:38 from (205.188.116.73):
In Reply to: Cub Timing posted by Brian in MA on June 22, 2007 at 05:29:59:
You need to bring No1 piston to TDC on the compression stroke. Remove the No1 sparkplug near the radiator and have someone to hand crank the engine while you hold your thumb over the plug hole until you feel compression. You can drop a large handle screwdriver on top of the piston and then watch the screwdriver rise as the engine is slowly cranked until it quits rising. You should be at at TDC and your timing mark should be aligned with the pointer. Make sure the handle is big enough so you don't drop it on top of piston. After your No1 piston is at TDC remove the cap and see where your rotor is pointing. It should be at the No1 plug tower that's close to 1 o'clock. If it isn't you need to pull the mag and turn the rotor to that position and reinstall the mag. Your plug wires should be in this firing order on the cap since the rotor turns CW. 2-1 4-3 Once you have the mag installed make sure its rotor is aligned with the No1 plug tower. If it isn't, pull the mag again and reinstall before you move the engine off TDC. If its rotor is at No1 try starting the engine. Hal
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
