Re: How do you know if they're bad?
Posted by Slappy on June 23, 2007 at 10:08:25 from (68.221.184.23):
In Reply to: Re: How do you know if they're bad? posted by JFAVOR on June 23, 2007 at 07:49:51:
The transmission in my 44 H rumbles a bit in neutral but I think this is normal, as I hear similar noise in others. If you hear transmission noise above the engine noise, that would seem excessive to me.
I haven"t gotten all the bearings out of the M yet, but I believe that there are two on each axle, two on the main drive gear and another in the casting between the differential and transmission, two on the countershaft, one rear PTO bearing, two pulley bearings (although you probably won"t need to change those since you are not likely to use anything belt driven), and two pinion bearings. So there may be 15+ bearings to replace.
If you get the mainshaft and countershaft out, its not too tough (just heavy) to get the bull and pinion gears out, so I would do it all at once. I"m taking Bob"s advice and swithcing sides on the pinion and bull gears to get a new surface.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
