Re: 54' 400 Diesel smoker
Posted by Janicholson on June 23, 2007 at 16:46:32 from (66.173.50.72):
In Reply to: 54' 400 Diesel smoker posted by mwood on June 23, 2007 at 16:19:10:
Contaminated oil with diesel fuel in it, or very old oil will burn easily, and smoke. If it starts well, and only needs a minute on gas to transfer to diesel well, I would suspect poor oil 15-40 rotella, or delo oil are top brands. Has it been worked hard, or is it mostly a toy low use tractor. Working them (with good oil can reduce smoke. Valve guides can also be an issue, But If all else fails, putting a set of sleeves and pistons in it may be the answer. Or live with it. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
