Re: M gear box fluid
Posted by williamf on June 24, 2007 at 07:29:55 from (66.82.9.86):
In Reply to: Re: M gear box fluid posted by Carden on June 24, 2007 at 05:48:08:
Most people use either 90wt or 85-140.
That plug checks the level for the transmission and rear end. There are two drain plugs, one for the transmission not far from the check plug and one at the far back, under the pto. The fill plug next to the shifter fills both. The M takes about thirteen gallons. That'll be a little sticker shock.
While it's drained and the rear plug is out is a good time to do a quick health checkup - take one of those little magnet-on-a-stick things and run it around inside, see if there's any metal chunks.
Good luck, Wm
