Re: Super MTA Hydraulics Operation
Posted by Smith1000 on June 24, 2007 at 16:35:38 from (70.41.100.224):
In Reply to: Re: Super MTA Hydraulics Operation posted by CNKS on June 24, 2007 at 14:07:27:
I see what you mean. Right now, I don't have a quick disconnect in line for it, but I could pick one up tomorrow. I have split the 3pt line to work a trip loader in front. There is a valve that toggles between the two, but it doesn't have an off position. Would be nice if it did.
I am thinking I should go ahead and put the drawbar back on. Like mentioned, it will probably be safer. I took it off about 17 years ago. I have it and the bolts and I think I kind of remember how it bolted on. The original frame part on the back is gone, but the 3 pt on it has a space where it slides through and then bolts ridgid with some clips to hold it down.
I can then let the 3 pt ride up to where it will stop on its own at the max height. The remote should then kick in. I am hoping this will work. If not, I look at something like the disconnect. Thanks.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
