Re: Head bolt Torque and sequence
Posted by El Toro on June 24, 2007 at 17:08:19 from (64.12.117.8):
In Reply to: Head bolt Torque and sequence posted by farmall newbie on June 24, 2007 at 16:43:04:
I have the torque listed at 110-ft-lbs. I don't have a sketch of the tightening sequence, but you can start in the middle of the head and tighten in both directions. You probably should use 4 different torques starting around 30-ft-lbs and then to 60, 90 and 110 ft-lbs. You need to keep to come back to the middle of the head when you increase the torque and keep tightening in both directions. You probably should retorque the bolts at 110-ft-lbs after the engine has been run.
Check the valve lash too. Hal
