Re: IH 1953 super c--hydralic fluid in crankcase
Posted by El Toro on June 24, 2007 at 18:43:19 from (152.163.100.197):
In Reply to: IH 1953 super c--hydralic fluid in crankcase posted by dan t on June 24, 2007 at 18:24:02:
third party image
You probably have a worn shaft where the seal in the pump contacts the shaft allowing hydraulic fluid into the engine. The pump will have to be pulled to do any repair. You may need a speedi- sleeve to cover the worn area on the shaft. Here's a parts breakdown on the pump. Hal
PS: Item No4 is the seal and No11 is the shaft that gets worn.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
