Re: runs rich
Posted by old on June 24, 2007 at 21:24:30 from (4.244.186.17):
In Reply to: runs rich posted by Randy Ecentral mn. on June 24, 2007 at 20:44:01:
Idle screw only works when your at idle. I.E. as slow as the engine will go. The main jet is the one you need to adjust and if you can close it up all the way and not kill the black smoke and the engine then you still have a carb problem. I have seen them where the main jet is just plain bad and needs to be replaced and or that its not even there any more because some one took it out and forgot to put in back in when they did a carb rebuild
