Re: Can't get rid of weak *spark*
Posted by Bob Kerr on June 25, 2007 at 03:12:37 from (64.12.117.8):
In Reply to: Can't get rid of weak *spark* posted by Jason1(Pa.) on June 24, 2007 at 18:48:46:
I worked on a neighbors Ford tractor that had problems with weak spark. Someone did a 12v "upgrade" and used an internal resistor coil with an external resistor. Took off the resistor, problem solved. you might check what the coil says on it.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
