Re: Raking hay in road ditches w/narrow front H!
Posted by Steven@ND on June 25, 2007 at 07:46:49 from (72.20.78.220):
In Reply to: Re: Raking hay in road ditches w/narrow front H! posted by Dave2N on June 25, 2007 at 05:29:08:
Yep, in talking with all the older fellas around here, the only time they've every tipped ANY tractor is with a loader on it... and the bucket raised over 6 feet in the air and usually with a load on it.
Darn narrow front sure makes the steering wheel kick when you hit a hole, though...
