806 3pt won't lower all the way
Posted by FM IN MN on June 25, 2007 at 18:31:18 from (69.19.14.34):
I have a 64 806 that needs some attention. The 3pt will only lower to the half way position. It operates fine from raised to half way. I removed the drop valve seat assembly with the engine off and the hitch lowered to the ground on its own. Is this the valve to replace or should I be looking at replacing the unloading valve under the seat or the relief valve next to the unloading valves? Any ideas?
