Re: 2400A (454) clutch
Posted by rret on June 27, 2007 at 04:48:11 from (24.151.127.169):
In Reply to: Re: 2400A (454) clutch posted by Janicholson on June 18, 2007 at 16:59:42:
split the 2400A tractor this past sunday. turns out that the throwout bearing had siezed real bad. that explains the noise. i think the smoke was the grease in the bearing burning off. the face of the bearing melted on the 3 clutch fingers. the PP, clutch disk, & flywheel looked fine with no signs of heat buildup.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
