400 crankshaft gear removal
Posted by SDE on June 27, 2007 at 19:43:05 from (69.179.1.9):
It appears that I will need to make a gear puller to get the gear off. Anyone with a suggestion on how go about this?
Will this gear be a real tight fit? Could a person be able to use two pry bars and get it to slide off?
Thank you
SDE
