Re: Governor bearings
Posted by Janicholson on June 28, 2007 at 14:24:46 from (66.173.50.83):
In Reply to: Governor bearings posted by Doug Coutts on June 28, 2007 at 11:55:07:
A bearing driver is what is best. I ulook at all of my sockets first to see if any are just right to push on the perimeter of the bushing. If so there it is. If not, they need to fit just under the bore size or the bearing will get crooked in the bore and be more difficult, and you need the driver to install the new bearing anyway. Making one out of bar stock, or schedule 40 pipe with a welded in plug to pound on is OK. Machining one is easy with a lathe. Or buying a driver from a tool store. JimN
