Re: govenor weights, roosa master injection pump, 560 Diesel
Posted by Bob on June 28, 2007 at 23:00:24 from (69.178.229.154):
In Reply to: govenor weights, roosa master injection pump, 560 Diesel posted by Tan67 on June 28, 2007 at 21:22:32:
What are you trying to do, blow it up???
You have to remove the top cover of the pump, take the governor linkage apart, then remove the metering valve.
The advance mechanism needs to be disconnected from the cam ring.
The "hydraulic head" has to be withdrawn from the pump housing, and the governor weight carrier and weights will come out with the hydraulic head.
