Re: Wire feed welding ?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by tom zander on February 08, 2000 at 18:21:14 from (152.163.197.208):
In Reply to: Wire feed welding ? posted by Steve K. on February 08, 2000 at 15:43:28:
If you are not spending big bucks for a welder get the flux core. I own an arco welder with a gas bottle and use a century welder at work. The cheaper century has out performed the arco.
Post A Followup
: Re: Re: Wire feed welding ?
