Re: backfiring
Posted by Janicholson on June 29, 2007 at 07:48:11 from (66.173.50.120):
In Reply to: backfiring posted by HENRY E NC on June 28, 2007 at 19:51:17:
In addition to setting the timing to the mark, I would make sure the load screw (front bottom of carb) is sdjusted so it is just as lean as it will run well under load. Usually about 2.5 turns out or so, will do it, but it is making good power that counts. If it is too rich and makes the inside of the muffler tip black, it is going to backfire more. They all backfire unless out of gasoline, so it is not abnormal. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
