Re: FARMALL H STEERING
Posted by Thomas D Windsor on June 29, 2007 at 19:09:45 from (71.28.91.75):
In Reply to: FARMALL H STEERING posted by ALBERT DEEM on June 29, 2007 at 18:14:15:
Up front, turn the wheel in a direction, L or R until the wheels start turning. Then, take a piece of masking tape and put it around the shaft up front right up against the edge of the hole where the shaft enters the gear box. Then turn the wheel the other way till it starts turning the wheels...you can then determine whether the shaft is going in and out rather than some other problem. If it is in fact moving in and out, as suggested below, you can get a washer spacer, start with thin and move to thicker, and put inside the nut and tighten it up till you get the play out of it...make sure it has plenty of grease.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
