Re: FARMALL SUPER M
Posted by John A. on June 29, 2007 at 19:19:44 from (4.253.1.130):
In Reply to: FARMALL SUPER M posted by ELVIN FRANK on June 29, 2007 at 13:21:42:
Elvin, You might as well just make up your mind to tear into this engine. At least pull the head so a better visual inspection can be done. Then IMO the easiest way to unstick this engine is to set a fire in each cylinder that is sureenough rusty. To do this remove the pan, loosen and remove the rod caps then, One at a time pour Diesel in a cylinder add a splash of gas set it on fire, wait till it burns itself out then drive, jack the piston out from the bottom. Now you can really tell if the piston/sleeves can be saved or new ones are needed. As usual be safety conscience get all flammables away, roll tractor outside, etc, etc. Later, John A.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
