Re: backfiring
Posted by Thomas D Windsor on June 29, 2007 at 19:21:30 from (71.28.91.75):
In Reply to: Re: backfiring posted by georgeky on June 29, 2007 at 09:42:21:
Henry,
These tractors are not precision engineered things...you can set the timing right on the mark and still have the problem. There is some slack in the distributor/magneto drive system. Under a load, you can be right on the money, but when you back off and cause the load on the gears to rock a little the other way...you will be a little off. I would check the timing at a little positve acceleration of the engine and make sure it is on the mark and then keep trucking! (I am certain you know there is a pin sticking out up front and there is a mark on the pulley)
TW
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
