Re: FARMALL SUPER M
Posted by Bob Kerr on June 29, 2007 at 20:37:36 from (152.163.100.197):
In Reply to: FARMALL SUPER M posted by ELVIN FRANK on June 29, 2007 at 13:21:42:
I few years back I bought a 10-20 that sat outside for many many years (estimated as many as 30-40 years). Stuck bad but in only 2 of the cyls. I tried a few things that didn't work like soaking and others and finally pulled the head off. I was glad I did! If I would have gotten the crank to turn, I would have destroyed the valve train as all valves were stuck tight as drums. heating with a torch, took 3 hours to get them out. as for the pistons, I took a small 1x2 block of ash wood and taper cut one end and gently tapped the piston edges on the left and right side (not above the wrist pins)until the piston started rocking, put just a little kero on the piston top and kept doing it and cleaning out the crud the kero brought up,until it turned. Took just a few hours! Those cyls had been wet for so long you couldn't tell where piston stopped and sleeve began, totally sealed up with rust. Some how I managed to save the sleaves and pistons!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
