Re: Farmall Super C rear axle replacement - Help needed
Posted by Harold Hubbard on June 30, 2007 at 05:38:32 from (66.6.176.23):
In Reply to: Re: Farmall Super C rear axle replacement - Help needed posted by Ed342 on June 29, 2007 at 22:12:35:
I have been through this movie several times with a C and two supers. There are two different types of bull gear. If you have the one that is a solid steel gear, it will last through several axles, even if the ends of the splines are a little damaged. If you have one with a steel rim riveted onto a cast iron hub, you will eventually take the splines out of it. The axles are a weak point in the C, Super C, 200, etc. I have not had as much trouble since I stopped plowing snow with the C. I think that the constant shuttling between forward and reverse, with chains on and heavy ballast, is really rough on the axles. I have always used the old gasket on the PTO housing, and bought new for the axle housing and the deck. I use just a thin smear of silicone to hold the gaskets in place for installation. You should also use non hardening sealer of some kind on the bolts that hold down the cover. Otherwise the specially designed IH water funneling bolt holes will add rainwater to your transmission oil. I don't know if IH ever gave a spec for the torques, but the deck and PTO aren't really critical, just tighten them up with a ratchet. The axle housing should be tightened just as hard as you can without getting stupid, and recheck it after a couple day's use. I don't have one handy, but there are generic torque charts available, with the torque based on the size and grade of the bolt. One of those will get you close enough, and is useful for other things as well.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
