Re: Largest reccomended bushog for an M???
Posted by georgeky on June 30, 2007 at 19:00:52 from (205.188.116.73):
In Reply to: Re: Largest reccomended bushog for an M??? posted by John M on June 30, 2007 at 18:16:21:
In most places 2nd. In some on flat smooth ground and not real thick it will pull it in 3rd. If in real thick grass that should be cut for hay 1st. I have pulled this mower for 20 years with M's. I have mowed locust thickets and thick blackberry briars. And cleaned up 3 or 4 farms with this very outfit. I know an old man in Winchester, KY that pulls 20 foot Woods mowers his M's on flat ground mostly, to clip pastures with. I mow lots of hills and can not pull a 20 footer on them. It will handle that mower as good as my 7610 Ford will, with the exception of power in thick grass.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
