Re: To twist or not to twist
Posted by Bob Kerr on June 30, 2007 at 20:53:46 from (205.188.116.73):
In Reply to: Re: To twist or not to twist posted by GeneMO on June 30, 2007 at 07:59:36:
Hi Gene, I had heard a long time ago that IH and a bunch of other maufactuers used lard oil for machining and cutting threads. When I took apart my 10-20 that sat outside for 30-40 years I only twisted off 3 bolts total on it and all the threads were still in good shape even the ones in the radiator!. If I replace a bolt with one that is plated, I remove the plating with acid, those plated bolts always get stuck bad and twist off especially if put together dry. My Grandpa used lard also, unsalted of course!.
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
