Super A radiator swap
Posted by R. Baker on July 01, 2007 at 16:03:32 from (70.152.175.3):
I have a Super A with a non pressue system. The radiator is shot so I want to go to a new pressurized system ( pressue radiator and water pump) however doing some research it apprears the pressurized radiator is not the same size as the non-pressue radiator. Questions are as follows:If I go with the non pressure radiator which will drop right in. There would be no overflow tube does this matter in a pressurized system?
2.Will the pressure radaiator (it appears to be smaller) work with my old type sheet metal including any bolt ups and putting on a pressure cap?
4. Will the pressurized cap work on the non pressure radiator? Thanks of the help
