Re: SA Oil pan leak
Posted by gene bender on July 01, 2007 at 18:45:19 from (67.55.226.214):
In Reply to: SA Oil pan leak posted by TWheat on July 01, 2007 at 17:34:42:
That capscrew goes into the front seal assy which is pot metal and easy to strip the threads. It is a blind hole and probably a too long a bolt was used. Just tap a 3/8 fine thread tap then use a 3/8 capscrew dont over tighten mite want to use a sealant on the threads. You can also drop the pan and replace the bottom assy of the seal. I have some good ones if you need one.
