Re: Clutch Bolt falling out
Posted by Nat 2 on July 01, 2007 at 22:46:36 from (64.80.108.52):
In Reply to: Re: Clutch Bolt falling out posted by LinemanFarmer on July 01, 2007 at 18:27:19:
Heck, you can replace the whole clutch and pressure plate on that tractor without splitting it... It's a little tricky, but doable. I've done an H before, myself, and I'm like a turtle on my back, totally helpless. If I can do it, anyone can. Worst part is dropping that liftall pump out.
