Re: dropping the Liftall Pump
Posted by dej(jed) on July 02, 2007 at 05:25:16 from (67.140.59.121):
In Reply to: dropping the Liftall Pump posted by LinemanFarmer on July 02, 2007 at 05:03:58:
There are 4 bolts coming up thru the bottom of the pump edge. You can see them if you look. First remove the 3 hydraulic pipes. Now unthread the fill pipe. Unbolt the lift all lever assembly by untreading the retaining bolt. Next remove the dust cover and disconnect the pump drive shaft, which is held in place by 2 cotter keys and 2 sleeves. Now remove the 4 bottom bolts and lower the pump from the belly of the tractor. A floor jack works best because the pump is fairly heavy. Now you can replace the clutch thru the opening.
