656 Hydro goes out of gear in forward
Posted by cgustafs on July 02, 2007 at 05:25:43 from (134.129.116.91):
My dad has 656 hydro. When you are going forward it works fine if you are in the lower half of the speed range. If you are in the upper 1/2 of the speed range, the hydro seems like it just goes into nuetral. There aren't any sounds like transmission teeth going out of gear, etc.... it just goes flat. If you push clutch (stop n inch) pedal, the system recovers and it will "go back in gear" and work again. Any suggestions what could be wrong? I have ordered shop manual to pressure test, but hasn't arrived yet. Just looking for prelim ideas.... thanks!
