Re: Clutch Bolt falling out
Posted by Bob Kerr on July 02, 2007 at 07:00:48 from (64.12.117.8):
In Reply to: Clutch Bolt falling out posted by LinemanFarmer on July 01, 2007 at 18:26:34:
My 48 M did the same thing, One of the coupler bolts and rubber washers fell out, but the bolts that hold the aluminum sleeve also came out. I put them back in and it is fine so far.
