Re: dropping the Liftall Pump
Posted by glennster on July 02, 2007 at 07:07:17 from (76.223.242.115):
In Reply to: dropping the Liftall Pump posted by LinemanFarmer on July 02, 2007 at 05:03:58:
i have a couple lenghts of round stock, pretty sure its 3/8, tap one end back about an inch on each one. remove two of the belly pump bolts kitty corner from each other, screw the rods in, i think mine are about 24 inches long. then put the floor jack undet the pump, remove the other two bolts let the jack down slow till its on the ground, then take the rods out. that pump is an awkward rascal, and like the other guys said, its heavy. ya may want to put a new seal and gasket in the pump when its out too if its leaking.
