Re: dropping the Liftall Pump
Posted by Bob Kerr on July 02, 2007 at 07:14:37 from (64.12.117.8):
In Reply to: Re: dropping the Liftall Pump posted by Bob Kerr on July 02, 2007 at 06:52:15:
OH yeah, don't forget this!, when raising it back up with the floor jack make sure it doesn't hang up on anything on the way up, like the driveshaft.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
