Re: help!!!-PLease 140-no oil pressure at gauge?
Posted by El Toro on July 02, 2007 at 12:13:11 from (64.12.117.8):
In Reply to: help!!!-PLease 140-no oil pressure at gauge? posted by BIG RED 1 on July 02, 2007 at 09:44:01:
Did you have the engine block dipped and the oil passages cleaned? Your oil gallery could be blocked with dirt or sludge. I would see if there's blockage in the block where your oil pressure gauge is connected. You can try to push a piece of wire into that hole and see if its plugged or open. Don't lose the wire. I wouldn't run the engine until you find the problem. Hal
