Re: B414 Engine Bearings
Posted by El Toro on July 02, 2007 at 14:05:28 from (152.163.100.197):
In Reply to: Re: B414 Engine Bearings posted by Lee B414 on July 02, 2007 at 12:25:31:
The IH P/N 710327R1 rod bearings are std in size
and cost about $20.00 each. The 710319R1 wasn't listed and the 710318 are listed as std mains and you would need to purchase the thrust main insert separate IH P/N 708910R91 for about $60.00.
They recommend buying the aftermarket bearing sets
and the P/N on the rod bearings is 241143 for $52.00 and the mains # 241149 for $75.00. These are std too.
You can call this place at 1-800-732-0017 and ask
for farm tractor parts. Your local Case/IH should be able to double check these numbers. Hal
