Re: Somky exhaust
Posted by jonnny2006 on July 02, 2007 at 16:32:53 from (67.142.130.42):
In Reply to: Somky exhaust posted by Ed W on July 02, 2007 at 16:00:45:
Is it grey or white? if it has a shade of white to it check your water level as to make sure it is not water being burned. If it is burning oil it will burn blue....thus check the oil daily. if it is burning black it is running way to rich. you might have a combo going on...try turning the main metering valve in a half a turn at as time till she starts to studder and back off 1/2 turn to 5/8 turn. pull the plugs and let us know how each one looks..... that can tell alot. How is it running when it smokes does it run rough or miss? Does it clear up after a while? does it do it only after hot? does it do it only under load? we could use a little more info...jonnny2006
