Re: H trans missing part!
Posted by D Slater on July 03, 2007 at 07:22:00 from (72.65.143.131):
In Reply to: H trans missing part! posted by Bob Kerr on July 02, 2007 at 21:16:32:
Never found one missing, I think if you put it togeather without a spacer when you tighten the bolt in center of front coupling it will put a preload on the ball bearings that they wern't designed for. On the other problem,is that the formed metal piece that goes between clutch shaft and transmission input shaft coupling that holes are to large? It could be worn out, but since the spacer was missing it makes me wonder if you have the correct bolts. The correct ones are bigger diameter on end toward head of bolt. Disreguard this if I'm refering to somthing different than what you mean.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
