Re: how to get the imput shaft out?
Posted by BF8690 on July 03, 2007 at 16:10:16 from (138.163.0.41):
In Reply to: how to get the imput shaft out? posted by LinemanFarmer on July 03, 2007 at 15:40:11:
Once you take the 4 tapered bolts out of the input shaft you to take off the clutch lever rod that goes from the clutch pedal to the throw bearing shaft on the left side of the bell housing. Disconnect it from the lever up forward on the throw bearing shaft. Then there are two bolt at the top of the bell housing on the inside. The two bolts connect to a tube that the throw out bearing slides on to the top of the bell housing. The input shaft from the clutch to the tranny also goes through this tube. Once you pull these two bolts out the next step is to remove the two bolts that connect the throw out bearing housing to the throw out bearing lever. There should be two washers that act as keyways on this throw out bearing lever shaft. Pull the two key way washers out. You have to slide the throw out lever towards the left side of the tractor and spin it to gain access to these keyway washers. Then slide the whole shaft out to left side of the tractor. After you remove all of this then the input shaft, throw bearing guide tube, throw bearing assembly, pressure palte, and friction plate can be removed all at the same time. Pay close atention to how it all comes out because you will have to install it in a reverse manner. I have done this a couple of times on my M. It is fairly easy to do if you have a helper standing by. I figured out how to do this by looking at the parts book for the clutch. The terminology that I used for the parts mentioned above may not be correct but by looking at where I'm talking about you can figure it out. By the way, if you have an M with a 12" clutch this will not work. Check you serial number then go to the parts section of this website. If you have a serial number that has an 11" clutch you can remove it how I said above.
Home
| Forums
Today's Featured Article -
The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
